Re: Derbi Motoplat ignition timing
Mike Bartell /
I'd try running an additional ground, directly from the magneto to the frame- just for getting it running.
as for the piston, if you are going to take it off anyway, check with the ports on the side- they should line up, unless they are exactly in the center.
I haven't seen any standardization in piston orentation- the arrow either points to the exhaust or the intake, but no telling between brands.
