franco morini cylinder studs
While rebuilding the engine on my 1978 Batachi Snark I found the the cylinder studs are stripped at the end and will need to be relaced. The engine is a franco morini MO1. I was wondering if anybody knows how I could come by new cylinder studs to purchase or even know how to make them.
Re: franco morini cylinder studs
Jason Luther /
i think actual studs are easy to come buy, mopedwarehouse and the like. but ive made an exhaust stud for a morini just out of a bolt with the proper threads, just cut the head off. i imagine you could get some threaded rod for the cylinder studs, although it wont have the same shear strength as the stud, i think it would be just fine. -jason
Either call BJ at Handy Bikes in Ohio: (614) 299-0550
or
visit <www.boltdepot.com> get metric allen head socket bolts, the 12.9 grade. Cylender studs for the Morini MO are size 6mm X 1.0, if you get the 100mm, put them in the crank case(put a drop or two of oil or anti-seize copper grease to prevent them rusting in), cut off the heads then thread the bolt with a 6mm X 1.0 die, you should be all set to roll out.
thanks for the ideas!
