Re: Seized Engine
John Joedicke /
Take the plug out and pour some Marvel mystery oil in and let it sit for a day or two.Then remove the head and see if you can roll the motor over with a little pressure on the piston. Keep working it back and forth, it probably will break free. New piston and rings probably, if the bottom end hasn't been fouled with moisture. Just as cheap to put a kit on it if it is only the top end.
