Re: Decompression valve problems
Ja'Far Rogers /
you don't need to take out the engine to set the points, hell you don't even have to remove the flywheel cover... i don't know if it had something to do with your decompressor (highly unlikely) but it was certainly unnecessary. if you were fooling around the with points and now your engine won't start it's more likely that you misadjusted the timing.
