Re: Decompression valve problems
Ja'Far Rogers /
Micheal is your decompressor valve in ANY away affected by your clutch? if so you must readjust both so that the decompressor valve is depressed just as the starter clutch is activated. check your service manual to obtain the precise clearance between the cylinder head and circlip. DO NOT push it in with a screwdriver man but _do_ blow the grime and grease out with an airgun.
