spark plug wires
i want to put on a new spark plug wire, is there anything i should know about doing that or can i just pull out the old one and connect the new one? the new one is more insulated and has a larger wire for a better current or whatever, i heard that this can help with overall performance.
Re: spark plug wires
John Joedicke /
What kind of Moped?
batavus badger
there is nothing wrong with the old one but i was told a thicker one would be better
John Joedicke /
The only trouble might be getting it to screw into the coil. If it is fixed like a Tomos you will need to get a splicer connection. Otherwise remove the old and install the new with the new cap to match.
rock, sounds easy enough, thanx
