Re: Long lasting intake bolts?
legendre /
"Blue Loctite" is a product that you apply to the threads of your bolts, not a type of replacement bolt. The Blue stuff is the lowest strength product (they have half a dozen grades, or more), but will hold your bolts in fine.
Make sure that the bolts & holes are clean, dry and free from any grease or oil before applying just a drop of the product to the bolts. Then reassemble & tighten to specs.
