Re: chain tnesion
Michael Vogt /
The chain needs to be tight enough so that it does not come off of the drive gears. But if the chain is to tight than it will wear out to quick. I usually tighten it until there is about 1/2 to 3/4" of play so I think it is tighten right. Also be sure to keep the chain well lubed hope this helps.
