puch clutch problem
Troy Brown /
when i pull the clutch lever,it takes at least 3 to 4 cranks on the peddle(right side only due to Hommet 6p pipe from 50cc.nl) before it turns over. what should i be looking for ?
Re: puch clutch problem
Troy Brown /
tbrd OP
help
Starter clutch cable too loose? Worn starter clutch pads? don-ohio
