bad spark qt 50
i have a 1984 yamaha qt 50.But the spark plug gap is about touching, this is about the only way i can get it to run.Just want to know if it a bad coil or something else ineed to look at.
Re: bad spark qt 50
It could possibly be a bad coil, but you also need to look at the points, condenser, wiring and plug wire & cap. The cap should measure around 5K Ohms, the wire should be clean and shiny on both ends. If the wire is molded into the coil, then don't worry about that end.
If unsure, get a new NGK plug cap, cut 1/4" from the end of the plug wire, and then install the new cap. Sometimes the wire insulation can be stiff, and it makes installing the new cap difficult. If this is the case, push a thin awl or pick 1/2" into the end of the plug wire, and then the cap will screw-on easier.
