Re: fuel leaking from carb@cylinder head
Len T /
If you remove the carb you'll see a small pin hole at the bottom bolt area....it goes thru the bolt area and into the intake of the carb. It's there as a safety valve,in case the float doesn't work properly....sometimes the pressure from the gas tank will force gas by the float , so you should shut off the gas vavle when stopped. I just went thru this with mine and had to install another shut off cause mine doesn't work. It solved the problem! Also pin point up on the float... Mine was the other way.
  fuel leaking from carb@cylinder headTopic by: tim tim 04/23/05 11:26PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/23/05 11:49PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/24/05 02:02AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/24/05 12:44PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/26/05 12:45AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/26/05 10:40AM
  Re: fuel leaking from carb@cylinder headRe: Matthew Scholtens Matthew Scholtens 04/26/05 09:36PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:45AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:36AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:45AM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/25/05 02:58PM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/26/05 11:51AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:41AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/27/05 01:40PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 02:34PM
  Re: fuel leaking from carb@cylinder headRe: John Joedicke John Joedicke 05/24/05 12:58PM
  Re: fuel leaking from carb@cylinder headRe: Joe Woods Joe Woods 05/24/05 02:51PM
  Re: fuel leaking from carb@cylinder headRe: Len T Len T 05/24/05 02:56AM
