Re: fuel leaking from carb@cylinder head
legendre /
You can get 3M wet-o-dry just about anyplace - hardware store, home depot, menards etc. I'd suggest a medium grit, like 180-200 grit, and use it wet.
If it's way out of true, start with a coarser grit, and finish up with medium or fine.
You can use a little of the orange permatex on an intake gasket, but just the thinnest smear. If you need more, then the parts need truing.
I would not torque a manifold flange that uses a thick gasket more than 4-6 ft/lbs, assuming 6mm bolts. This is one of those places where the "mechanics feel" is very helpful..
  fuel leaking from carb@cylinder headTopic by: tim tim 04/23/05 11:26PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/23/05 11:49PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/24/05 02:02AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/24/05 12:44PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/26/05 12:45AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/26/05 10:40AM
  Re: fuel leaking from carb@cylinder headRe: Matthew Scholtens Matthew Scholtens 04/26/05 09:36PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:45AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:36AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:45AM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/25/05 02:58PM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/26/05 11:51AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:41AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/27/05 01:40PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 02:34PM
  Re: fuel leaking from carb@cylinder headRe: John Joedicke John Joedicke 05/24/05 12:58PM
  Re: fuel leaking from carb@cylinder headRe: Joe Woods Joe Woods 05/24/05 02:51PM
  Re: fuel leaking from carb@cylinder headRe: Len T Len T 05/24/05 02:56AM
