Re: fuel leaking from carb@cylinder head
Don Pflueger /
sorry, i reread this. i thought you meant cylinder head bolts. there is a torque spec for 10mm bolts. i think you can find it in the back of the batavus service manual, if not, i can look it up in my dealers service manuals. you dont want to use anything like form a gasket on an intake. do like legendre said and make sure the mating surfaces are flush. then you can use a brush on atv sealant. put it on very thin tho. you dont want it to squish out into the intake when you tighten the bolts.
  fuel leaking from carb@cylinder headTopic by: tim tim 04/23/05 11:26PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/23/05 11:49PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/24/05 02:02AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/24/05 12:44PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/26/05 12:45AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/26/05 10:40AM
  Re: fuel leaking from carb@cylinder headRe: Matthew Scholtens Matthew Scholtens 04/26/05 09:36PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:45AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:36AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:45AM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/25/05 02:58PM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/26/05 11:51AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:41AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/27/05 01:40PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 02:34PM
  Re: fuel leaking from carb@cylinder headRe: John Joedicke John Joedicke 05/24/05 12:58PM
  Re: fuel leaking from carb@cylinder headRe: Joe Woods Joe Woods 05/24/05 02:51PM
  Re: fuel leaking from carb@cylinder headRe: Len T Len T 05/24/05 02:56AM
