fuel leaking from carb@cylinder head
tim /
hi, i have a 1980 batavus m-48. i would like to know if i should tighten the 10mm bolts, as tight as can be, or leave them snug(as they are right). i have fuel coming out after traveling about 1 mile, it not much but this is probably why it stalls out after operating for about a mile.( (starts right up w/ the choke) this is a dicontinued carb, and i want to find out if the bolts are snug , not over-tightened should i locate something for the gasket. thanks, -tim
  fuel leaking from carb@cylinder headTopic by: tim tim 04/23/05 11:26PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/23/05 11:49PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/24/05 02:02AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/24/05 12:44PM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/26/05 12:45AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/26/05 10:40AM
  Re: fuel leaking from carb@cylinder headRe: Matthew Scholtens Matthew Scholtens 04/26/05 09:36PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:45AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:36AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/24/05 08:45AM
  Re: fuel leaking from carb@cylinder headRe: tim tim 04/25/05 02:58PM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/26/05 11:51AM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 10:41AM
  Re: fuel leaking from carb@cylinder headRe: Don Pflueger Don Pflueger 04/27/05 01:40PM
  Re: fuel leaking from carb@cylinder headRe: legendre legendre 04/27/05 02:34PM
  Re: fuel leaking from carb@cylinder headRe: John Joedicke John Joedicke 05/24/05 12:58PM
  Re: fuel leaking from carb@cylinder headRe: Joe Woods Joe Woods 05/24/05 02:51PM
  Re: fuel leaking from carb@cylinder headRe: Len T Len T 05/24/05 02:56AM
