carb?
i dont know much about 2 cycle engines, can someone tell me how to resolve this, fuel is leaking out of the carburetor (possibly)
thanks
Re: carb?
Don Pflueger /
there are a few things that cause a carb to leak
dirt in the needle and seat
worn needle and seat
leaking float
rusty or float hinge pin
stuck float
bad gasket
rust hole in the float bowl
cracked carb body
incorrect float setting
Re: carb?
Seth,
Is it leaking from the body of the carb, or from the air intake?
If it's from the body, then don pretty well covered it. If it's leaking from the air intake, this is a common issue with 2-cycle engines - esp. piston-port designs.
Make sure that there is not excessive carbon plugging the exhaust port / pipe, and that you are using an original-type air filter / airbox.
Re: carb?
i attached a picture on the original message, if that can assist.
Re: carb?
Don Pflueger /
yea but we cant see inside the carb. you need to remove it and take it completely apart and look for any of the things i listed.
