moped engine
i am having trouble with my 81 general. It runs but has no power. everything is connected and good. What is wrong??
thanks
moped engine
Sounds like the J-17 clevis bracket to me.
Re: moped engine
It is a little vague, Perhaps some more specific sympoms would help. four stroking, stalling etc
Re: moped engine
First.............did you replace the spark plug? Second.....is the muffler possibly plugged with carbon? Third........could the points have slipped shut or the throttle cable not be adjusted right? DON-OHIO
Re: moped engine
Kevin B. /
kev OP
the thing is it runs great when it is moving. Up on the stand that is. once it comes off it dies. Also it can be driven but when you stop it also stalls. Is there any possibility that it is a clutch. when it is running it tends to make a squeeling sound! Thanks for the help!
Re: moped engine
mess with the idle adjust screws, and if that doesnt work, clean the carb and exaust thuroughly
Re: moped engine
Sounds like the clutch. You can drive aslong as you dont stop. Correct?
Re: moped engine
Kevin B. /
kev OP
yea i can drive
is there any way to adjust the clutch?
thanks
Re: moped engine
Kevin B. /
kev OP
~Bump~
Re: moped engine
Kevin B. /
kev OP
another ~Bump~
