Honda express question
Jim Pommerening /
Starting problems -I definitly have a good spark[new plug],took a compression test 100 lbs.cold,and cleaned carb [soaked it in carb cleaner and used compressed air in all passages and jets].Still no start pulled plug double checked for spark and its there ,sprayed some starting fluid in plug hole put back plug and tried ,still no start.Any ideas on what to try next?
Re: Honda express question
Jim Pommerening /
Anyone know what compression is specified to be by honda .Is 100 too low?
Jonas Quimby /
100 is on the low-but-okay side. Normal is 130-145. 100 should still run it.
Check out the guide I wrote up on the subject.
" https://www.mopedarmy.com/forums/discuss/read.php?f=6&i=5035&t=5035":url
That should getcha going.
Matthew Scholtens /
Hey Jax184, the link is out dated. Can you repost with a current one? Thanks.
Jonas Quimby /
Matthew Scholtens /
Awesome. Thanks for putting it again.
Matthew
