Dexron III in an A35
Nick Eiselstein /
can you use drxron III in the A35 tomos engines or should I stick just to the type a or type f?
Re: Dexron III in an A35
use dextron III
Don Pflueger /
use typa suffix a or type f
Don Pflueger /
dexron III is a multi application fluid. it has additives that saturate the cork in a35 clutches which causes them the wear faster.
whoops, I told him that because that's what Ike uses. I thought a dealer couldn't be wrong.
Don Pflueger /
i dont know what ike uses. i just use what is recommended.
donp.. will Mobil 1 Synthetic tranny fluid have the same effect on a Puch 2 speed tranny??
Don Pflueger /
i cant answer that truthfully. i'm not a puch man.
Ike uses NAPA ATF Type F trans fluid. i have been at his house 5-6 times. thats what he uses, he may use dextron in a puch or other engine of his?
I also use Mobil 1 sythetic trans oil for my 1999 Tomos LX. I thought this oil would be the best? Am I wrong?
Don Pflueger /
not if it's a compatible replacement.
