moped stalling after driving
my 1982 eagle 2 will ride for a while then the motor comes to a real low growl and if you hit the gas more it will stall what do i do i just put a new plug in
Re: moped stalling after driving
sounds like it might be "four stroking"
try making sure your air filter is clean.
Don Pflueger /
clean your gas cap vent
Michael Vogt /
That is the same problem that i had with my moped.
you can try to leave the gas cap a little loose and see if that helps(You my have a airlock in your gastank)-and if this does not work you can take your sparkplug and clean it or replace it but make sure that it is gaped right-and if that does not work you can try to regap the points and make sure that you clean the points VERY GOOD.
I did all of that to my moped and now it works great.
And a big thanks to all of the good people who told me how to fix my moped.
