Re: Fresh from winter storage. What should I do? G
Steamboat Aka J. R. Stevens /
First drain all the gas from your tank and dispose of it then mix a new batch with proper gas/oil ratio and follow the previous instructions. Over time gas in he carb will evaporate leaving a gooey mess in the carb so after putting in the fresh gas, if your bike does not run well, you must clean the carb. Jim.
