Can't get maxi running???
I was trying to grt the maxi running today.
I hate to say it but I left gas in the carb wit no stabilizer.I used carb cleaner to get it running for about 2-3 seconds then it dies.The carb seems to get plenty of gas when i push the tickler down it over flows, and the spark plug was wet with gas before i used the carb cleaner. Do you guys think it's not getting enough gas through main jet because of clogging.Thanks
Re: Can't get maxi running???
ಠ_ಠ Jon Folks ಠ_ಠ /
It could be. Just unscrew the bowl and clean it. Also consider checking your spark plug and cleaning the points.
Brooklyn
Jim Madden /
I got it running today.since it sat all winter with gas in the carb the main jet was clogged with dried gas.I cleanded it up and it started on the first try.Thanks for your Help.
