fa50 carb settings
I was wondering if anyone out there knew the stock carb settings for an 84 fa50. just installed a new piston and rings and obtained a new used carb. trying to make run. thanks
Re: fa50 carb settings
Well, my '87 only has an idle speed adjustment. on the carb. it won't do anything without the air filter though, if the carb is clean mine has been very reliable, otherwise I'd start by cleaning the carb then tighten the needle all the way then loosen it 1.5-2 turns that should start it then tune it from there.
