puch throttle assembly
i have a 76 puch maxi. the throttle cable broke the other day 6 miles from my house and i had to run beside it . the current throttle assembly doesn't work well so I picked up a used one with the slide and set screw and also a new throttle cable. i can't figure out where or how toattach the throttle cable in the assembly. have some ideas? just don't want to screw things up. thanks, bee
Re: puch throttle assembly
nevermind, im retarded
hey bee.. just so you know.. Puch replaced all the kind you are replacing with the screw type cause the double ended one kept popping out... just cut the cable end off and use the screw slider! It's the best setup anyway!
