Fired up my puch today
i just fired up my puch maxi luxe 1980 one speed
it was runnin better than ever with half of the new gaskets in
anyways
an older problem came back
the ped runs great and all but if i twist the throttle any more than half way the engine wants to stall
i thought i fixed this before putting the ped away last year but it seems to have come back
any ideas?
i will have to clean the carb again this year and see if that helps and i will get a new plug too
Re: Fired up my puch today
sorry, i forget to put this in the repair form
well the throttle/stall problem went away
i just took a 5 min. drive around the block
i noticed that any speed above 20 the rear of the ped would start to wobble left and right
i think its because my rear wheel is not too good
its out of true
think thats how its spelt
anyways
can i take it to a bike shop to have it fixed up?
Dave,
Check some of these thing for problems:
Unclean carburetor
Blockage in your fuel lines.
Bad points
Incorrect spark plug gap
Timing
Air leaking in through a gasket
Reed valve leaking or broken.
Rob
Also, make sure your exhaust is not clogged with carbon.
yea ill have to try to get the baffel out of the exhaust
the outer "shell" is bent towards the end of the pipe and the baffel gets stuck in there really easy
if worst comes to worst ill cut it open with the angel grinder then weld it closed
i plan on cleaning my points as that has never been done and i will clean the carb this year again
after that ill replace all of the gaskets with the new ones i have and hope this helps my ped
all the gaskets are on
i fired on the puch and thought i did somthing wrong cuz it would not fire
but after a min. or 2 it fired
after the first kick i noticed i had MUCH better compression but my ped still wants to stall if i throttle it more than 3/4 of full
the ped runs fine on full throttle if i put the choke down a bit
is it getting too much air?
i still have to clean the exhaust
and clean the carb
i tell ya
ill never install another base gasket again
the old one was stuck on there real good
inded up scraping it off with a screw driver and there still a bit left on there
Smitty Smith /
It's possible that if you left ANY old gasket material on the cylinder bottom, or the crankcase, that you may have an air leak in that area.
When I clean carbs, I use a bread-tie wire to poke through the jet and tiny passeges in the carb. It's the only wire I've found thin and strong enough to push through gum in the carb, and not enlarge the hole size.
Hope this helps.
Tyler Jacobson /
check to make sure the little black plug with the oval hole in it is on the end of your air filter breather hole.
the air plug in on there and i will use some rubbing alcohol to remove the rest of the gasket
i think rubbing alcohol will do the trick
Edit:
the air plus IS on there...
we need an edit button
lol
