Re: '80 Puch won't start
Guillaume Bergeron /
clean the fuel line by clowing trough it...
also, the petcock (fuel valve, at the tank) may be clogged with small rust or dirt particiles comming from the tank.
If you ran the bike with this brown gaz, i would suggest you to clean the carburetor, which is most likely clogged or really dirty because of the gaz.
Simple remove it and un assemble it...
i would suggest you to work on a clean white rag.
BE CAREFULL, do not loose any part...
try to remember where each part goes.
clean is with compressed air, it can be usefull to have a compressor...
then reassemble everything, make sure that there is gaz flowing trought the fuel line, and plug the fuel line on the carb.
Pedal, and it should go VROUMMMM
good luck
g.b.
