Throttle Cable Lube
Do you have to lubricate throttle cables?
if so, with what and how?
Re: Throttle Cable Lube
Don Pflueger /
wd 40 works fine and is easy to find
Xyplestop Florbledo /
I use a dropper, and drip 20-50 down the cable, working the cable as I go to keep it moving, WD-40 is ok, but it does not hold up.........
Don Pflueger /
no it really doesnt. needs to be reapplied every so often. i personally use chain and cable fluid. its designed for the cables in winches. it soals in and penetrates, and then lubricates. it wont wash off with water either. but, its not a chain lube per' se like a motorcycle chain lube. it does not have the properties to remain on at a high speed. but i've never seen a better product anywhere. it is the best penetrant i've ever used.
if its like my puch
just open the little plug on the throttle cable and pump in the lube
