Plug chop is okay only when filter removed!?!
I just fired my sachs for the first time this year...
i think it made the same thing last year, but now i need to know why.
My moped is a sachs g-4, everything is STOCK!
my filter is clean, and no big restrictions... except for original ones...
i made a plug chop with filter, and the plug was WET AND BLACK
so i'm telling to myself... must not receive engough air...
for fun, i remove my filter, and do another plug chop...
the color is a sweet light brown, probably a little to light, should be a little bit richer i think.
here's what i checked/did:
-my choke isnt stuck.
-i'm using original jet.
-all the bolts are tight, near the carb and engine
-i cleaned the carb, at least 4 times.
-my airbox is clean
i'm sure someone here can help, it's probably a simple question, but i cant seem to find what's happening.
without the filter, it runs like a dream... but... i dont want to ride it without the filter, and i want it to run well...
anyway, any help will be HIGHLY appreciated
thanks a lot!!!
G.B.
Re: Plug chop is okay only when filter removed!?!
Steamboat Aka J. R. Stevens /
Your filter may be dirty or wet. A filter may look clean but be stopped up. I suggest you change the filter and do another plug chop. Jim.
Guillaume Bergeron /
Humm, damn
the filter cost a lot!
on mopedjunkyard, they charge 40$, only for the paper part.
on mopedwarehouse, they charge 14$, but they are high on shipping...
what do you think about a generic air filter cut to fit the airbox size?
g.b.
I have no experience with your bike. I hope some one else will respond. Jim
