any point/condencer website to order online
and will i need any additionol tools i dont know if i need a wheel puller or i can change p/c i dont want to remove the center housing nut covering the p/c without knowing what proper toolls to have thanks to all - tim
Re: any point/condencer website to order online
Don Pflueger /
you should get a puller designed for your brand of flywheel.
thanks do i need it to work on the pnts/cond.?
Don Pflueger /
yep. if you dont remove the flywheel, you cant replace the points or condensor.
I have a 2-3 prong flywheel puller. Works great on flywheels
If you get the specific flywheel puller though for a few diff bikes its a tool that dosnt get used much unlike the universal one.
Also a hint to all. Put some light oil on the flywheel shaft when you reasembe it. It makes taking the flywheel off again alot easyer if the new points are defective.
hi harry,
were did you get your flywheel puller. what do you mean by 2-3. i looked at a puller on the mopedjunkyard website and i cant understand how it works.
when i remove the center nut, does the wheel puller screw on where the nut was? the pulller looked like a tubular metal with a bolt head coming out of the top, thanks -tim
theres a set motobecasne tools on ebay for like 30
