Lubricating flywheel
how do you lubricate a flywheel?
Re: Lubricating flywheel
Smitty Smith /
on the stator plate is a swab, that rides the flywheel lobe that works the points. One drop of 3-in-1 oil, or something similar does the trick. Do NOT soak the swab, as you will contaminate the points, it only takes a drop.
