Re: 1980 moped spark help
tim /
batavus starflite,i was thinking of spraying contact cleaner on the points.but then donp suggested wet pionts would stop spark so i dont want to spry contact cleaner unless anyone says it would be alright. i will check the tail/head lights and wiring. in thee event of a weak condenser, will i have to remove the entire drive shaft or jcan i change the points/condeser by removing the housing cover(one nut in middle 11/16)i want to know when ordering poiinnts/condenser do i need to order the drive shaft puller tool. thanks -tim
