Re: Puch Throttle
Smitty Smith /
do you have it adjusted so that as soon as you start to twist it, it speeds the engine, or does it have a "dead-spot" at the beginning of the twist?
Also, are there any strands of cbale catching anywhere. What type of throttle do you have, the cable with a barrel end that goes into a slot, and wraps around the inside part of the throttle, or plain end cable that is secured by a setscrew in a slide under the throttle control?
