My motor won't catch
Ok. Here is the thing. I have a 62 Solex and when i put the motor down on the wheel, it will make noise and turn over as I pedal but won't catch. When i stop pedaling, it stops. This is the first time I have taken it out this year and last year it worked fine. Any suggestions?
Re: My motor won't catch
Probably either a blocked fuel line,old gas or ignition points are corroded some. Did you REPLACE that spark plug. Always do that first,Kristin. don-ohio
