I HATE PUCH WIRING
Is there a better way to rig up a puchs wiring? Anything would be better than the huge mess of wires on the right side.
Re: I HATE PUCH WIRING
lol Beamer kinda like a knot of spaghetti :P
No kidding - especially once the rubber starts drying out. It's like a .. dried out .. knot of spaghetti
puchs are so easy to rewire the only thing that sucks is the wiring block i just remove them and hard wire it
Philip Arnold /
I thought of removing the wiring block too. It must serve some purpose though. does anyone know what that might be?
pda
its mostly to make it easyer to remove the engine so you dont have to cut any wires
exactly, you cant remove the engine without that block. Maybe I'll put some little weatherproof M/F clips so I can just unplug them and drop the engine. Might make a bigger mess though.
how many times do you actually drop the engine you can always make the engine wires unplug
Yeah those european wiring blocks are a corrosive wires best friend.Just remove the original block and replace it with a screw terminal block availiable at radio shack. Put ring teminals on the wires make sure to solder the ring terminals to the wires so you won't develop any corrosion, and just screw the wires to the terminals. Much better connections than the originals and can easily be removed for engine removal.
im planning on rewiring my puch
ill remove all the wires and keep the ones that come out of the engine
you can get european wiring blocks from radioshack
they also make other designs but the european wiring blocks are the smallest ive seen
shoudl have a fun time looking at the puch wiring sheet
