Re: minarelli engine mounts?
Don Ohio /
Take the bike and engine down to your nearest privately owned muffler shop and ask them if they can bend the mounts back. They are used to `making do' with imperfect fitting pipes and flanges. If it's a General top-tank, I'd recommend you remove the bigh gas tank and carb. and shield the intake pipe with tin foil or something.But if it has the gas tank in the frame, make SURE they know that before they heat and bend anything. don-ohio (:^)
