flywheel
Philip Arnold /
is there any to pull the flywheel without a flywheel puller? I have no spark on my murray and have checked everything. I do have a burnt out taillight but my manual doesnt say that will keep me from getting a spark. I'm thinking the points or condenser are burnt. Besides the taillight thats all it could be.
pda
Re: flywheel
The manual almost NEVER tells you that the burned out taillight bulb prevents spark. At least I haven't seen it maybe only once. You need a taillight for safe riding anyway. Fix it. don-ohio (:^)
Re: flywheel
ya its cheap fix and it could be the prob... neva know...and to get the flywheel off just losen the nut and tap around the flywheel with a hammer if that dont work u could take a chance lol (this is only when all else fails) screw the nut on bout 6 thread and hit the nut with a hammer...lol good chance of ruining crank shaft.........way cheaper and less risky if u just buy a flywheel puller..
BlAiR
Re: flywheel
Mechanics secret.....beveled fittings. just hit the flywheel with a hammer round and round till its pops off. This works with everything from tie rods to steering knuckles. Bigger part....bigger hammer. heres a picture to explain better
Re: flywheel
Don Pflueger /
NEVER HIT A FLYWHEEL WITH A HAMMER!
doing so breaks or loosens the magnets inside it.
Re: flywheel
Don Pflueger /
that secret could be very costly when you use that method to remove a tecumseh flywheel and you break the glue joints that hold the magnets in place. they are $80.00 and more to replace. you NEVER hit a flywheel with a hammer. take it from a real mechanic. thats what pullers are made for.
Re: flywheel
Philip Arnold /
ok ok I'll buy the tail light and WON'T hit it with a hammer!! Where in the world do I get a puller from? I'm thinking of taking a small engine repair class and starting a ped garage with my little bro, there isn't one here that will work on older peds! I don't know y though cause there easier than new ones! Thanks guys!
pda
Re: flywheel
Don Pflueger /
mopedwarehouse sells them. ebay. ikes bikes. most tool suppliers such as mac or snap on. sears.
Re: flywheel
Re: flywheel
Philip Arnold /
ok so I found some pullers. am i correct, they just screw on and you pull it off?
pda
Re: flywheel
James Foster /
Well, there's actually two kinds of pullers that I know of; 2-3 jaw sprocket pullers(like in the attachment above), and the draw-bolt type pullers. Personally, I've been using the 3 jaw sprocket puller I got from Autozone, and it works just fine as long as you adjust it correctly. The ones like at MWH are probably easier though, so you might want to purchase one like that if you're flywheel is designed for it. Whether you ask around at auto parts stores or shop online, you should find just what you're looking for. :)
Hope this helps,
JF
Re: flywheel
Philip Arnold /
thanks
Re: flywheel
Be careful with jawed pullers.........they apply way more force than you are feeling with the wrench and they can bend your flywheel edges. The BEST puller is the one that screws into the flywheel itself,and the inner screw pushes it away from the crankshaft. Cost 20 bucks. don-ohio (:^)
Re: flywheel
James Foster /
Good point Don, I just thought I'd mention it incase it was a flywheel that didn't have the ability to use the other type. I have to use a jaw puller on my honda because it's flywheel can't use the other type. Go with Don's advice Damon, and just be careful if you end up using a sprocket puller. Let me know if all goes well or not. :)
JF
Re: flywheel
UM... Shouldn't you simply try replacing the bulb before you get involved in ripping the motor apart??? lol
I always do the hard stuff first and then find out it was the simple fix all along (very dumb dumb dumb) ... it's how i ended up rebuilding my ped lol :P
