My sachs prefers right turns?
Hami Onder /
My Sachs is making a noise from the tranny that sounds like a clanking or metal banging around. But it only does it when i make a left turn when the bike is leaned over a little. Thats the side with the tranny on it.
I dont think i have enough fluid in there and the fluid thats in there is the wrong kind. Could that be the problem?
Ummm
I know that this is probably completely off the wall, but have you considered putting the right amouny of the proper fluid in there??
Re: My sachs prefers right turns?
Could it be a swingarm clearance or chain slapping issue? don-ohio
if it is tranny then i think its to late for the right fluid or the right emount of fluis lol its alwayz bad when a tranny is making a noise lol
BlAiR
Hami Onder /
hami OP
Well the noise doesnt seem to affect anything performance wise. But then again, right when it starts i let off the throtle. Its just anoying having to coast through left turns then gun it when i straighten out.
you may have sheared a tooth on a gear. did you open it up? try adding more fluid and if it continues then your gonna have to open her up and take a look. metal sounds in tranny are never good.
