Re: Airsal Kit
Jeff G /
Adam, since your choke kicks off I would said that you are getting full throttle. Two other things come to mind you might check. One is did you put the piston in correct with the square hole up towards the intake side? Number two is your exhaust new? If not maybe it is clogged up some what.
