fuel line 1/4 tube how do you hillbilly hookup
Ricardo Bowring /
hey guys how do you guys hook up the fuel line with gas remnants on the petcock by adding flame (burning it to fit)to the tube etc...
Re: fuel line 1/4 tube how do you hillbilly hookup
I am guessing you're talking about the clear plastic tubing?
You can get it soft with a hair dryer. But STILL keep that away from raw gas and the tank. don-ohio (:^)
Ricardo Bowring /
rico OP
ok thanks don-ohio....
Rico,
Use a lighter to melt the end that will hook up to the petcock and wet your fingers and squeeze the ends to make it smaller. Dip in water to cool off, and put it on. Should work.
If not, a small hose clamp would work great.
Hey, hows that Solo engine going for you? I hooked up mine yesterday and it ran beautifully!
EK
