garelli crank
im having trouble removing my 77 garelli gransport right crank
how exactly do i remove this crank?
thanks
Re: garelli crank
what do you mean by right crank? i have an 80 garelli
Re: garelli crank
the right side crank arm for the pedal. i cant get the damn thing off
Re: garelli crank
well....this can be difficult if its really damn stuck theres a few options. you could use a two arm pully remover....or better yet...heat up the damn thing with a torch and knock it off with a hammer. the torch WILL work easier than the pully puller. good luck man!
