Why do dellorto carbs...
suck. Not really suck but why is it that the choke sticks on them. i have purchased a couple of tomos' and every time i have to yank on the throttle cable to disengage the choke. is this a common problem that can be remedied? or am i stuck with this burden?
Re: Why do dellorto carbs...
knowing how the choke works on them, you will have to live with it. This is why some carbs have a lever on the body to use or release the choke. These always work.
Don Pflueger /
thats how they work. they are a much better carb than an encarwi or bing in my opinion.
Dellortos are the best. I wouldn't use anything else.
dellortos are the shit.
They'll even stand up to the almighty poohammer.
If your throttle's adjusted right, and the choke is still sticking, you may have a worn cable with too much flex inside(too much `give'). But I'll admit I wish the Dellorto had a choke lever on the handlebar. don-ohio (:^)
