Puch declutching problem
Richard Wells /
Have Puch 1977 Maxi
At sometime the declutching lever was broken off and replaced with a rube-goldberg circular aluminum plate. When I engage the clutch to start engine should the declutching shaft turn clockwise or counterclockwise to engage when I pull the hand lever for clutch on left handle bar.
The cable from the hand-lever to the declutching lever has been rerouted and seems to be in a terrible bind, pulling the shaft in a clockwise direction.
Can someone just explain how this declutching system is designed to work?
HELP ... and thanks
