Re: Low pwer up hills
Jason Luther /
is your idle real high? that will cause the clutch to engage, pulling a little from stop. there is a small adjustment screw on the side of the carb to adjust idle. out for lower idle. all mopeds suck on hills, although 20mph on the flats seem a little low. use freds guide in the resources section of this site to get your ped tuned right. depending on the horsepower model you have it should be 25 to 30 mph. keep any questions coming.-jason
