Replacing Belt - Motobecane 50v '79
Okay!
My belts are all crazy cracked! I need to replace these! What exactly are the steps involved?
1.) Remove Variator
2.) Remove Belt and replace
3.) Re-attache Variator
Does the clutch have to come off?
Is this how it goes? I do not have any of the specialty tools for the bike, so can I still do this? I have a large metric tool set, will that do?
What type of belt do I use? Brand and #, that I can get at the autostore?
Re: Replacing Belt - Motobecane 50v '79
The belt should be available locally. Do a search on this site.
Hami Onder /
No im pretty sure you need a special variator belt. I think the width or the belt is important to the variator. Which means you need a belt made for the bike. Can anyone a little more experienced back me up on that?
When i replaced mine all i had to do what remove the cover over the variator. Then you just muscle it on. Using a screwdriver to wedge it on is what i did.
So, no need to remove it from the bike, just the cover?
Where did you get replacement? The one at the mopedjunkyard must be found somewhere else...
Thanks,
Fred
Hami Onder /
i looked everywhere and finaly found one on ebay. And yeah, there is a cover that screws over the variator just remove that and pry it out with a screwdriver. if its too tight then you have to take the whole variator off.
Email mopedjunkyard im sure they can get one for you.
I was out looking at it at lunch. I see where the cover fits on. I got a #9313 at the auto store which bret says will work fine. I will try it out.
The belt will be unusable after i take it off...so I can just cut it.
Thanks,
Fred
I allready email fred, but just in case some one else sees this
DO NOT REMOVE THE VARIATOR just pull the belt off the pedal pulley
I used a 4l32 belt from napa for relacement It works fine
here is a forum about motobecane belts https://www.mopedarmy.com/forums/discuss/6/5375/5375/
