Re: motobecane newby
Paul Mehalko /
Obvious your reply's don't own a Moby. It's a tight fit to get
a socket in there. I use a 13/16 spark plug socket with a hex end on it. Also you have to take the rubber padding out of the inside of it so you can angle the socket to get on the plug. I then use a regular wrench on the socket to turn the plug.
