compression problems
i have a tomos bullet w/ a a-3 engine on it w/ compression problems. it is reading 90 maximum pressure. so i replace the piston, cylinder, and rings. unfortunately im still only reading 90 on compression. is there any were else i may be losing pressure that i may have not checked? any help will be appreciated.
Re: compression problems
Don Pflueger /
there's only a few places compression can be lost.
rings
head and cylinder mating surfaces
cylinder to engine case mating surfaces
crank seals
reeds
loose spark plug
lack of or missing exhaust exhaust
Steamboat Aka J. R. Stevens /
Hey Donp, as you pointed out, the compression may increase after break in of the new rings and cylinder. Jim
Don Pflueger /
yep, it might. 90 is a little too low tho. does it run? if so, i wonder if the guage is bad?
Don Pflueger /
i dont know why i didnt think of this before. must be slipping in my old age.
do you have the throttle held wide open when checking compression?
not opening the throttle limits the amount of air drawn into the cylinder and will give you much lower readings.
also, if its still low with wide open throttle. take the bike to a lawn mower shop or automotive shop and ask them if they can do a leak down test. this will tell you exactly where your compression is going.
