motobecane sparkplug gap?
hello, i own a motobecane cady and i need to know what the sparkplug gap should be set to?
Re: motobecane sparkplug gap?
i run all mine at between 25 and 30 thousanths of an inch
Jordan /
OP
all mopeds are set up differently. do you own a motobecane?
Jason Luther /
its either .03 or .018. depending on the plug, you'll know when you measure it. either or cant be as far off as the other. if that makes any sense at all.-jason
champion l86c or bosch b5hs
gapped .4mm (.015") to .5mm (.019")
from Haynes mobylette manual
According to the Cady owner's manual which I got a hold of recently, the gap should be "4/10 mm (.012 -.016")."
The Cady service manual says that the following plugs will work:
Bosch 436, A C 430Z, Champion L88A.
The Cady seems to have different specs than the other motobecane models.
It's electrical system is 6V.
Thor
PS. The owner's manual also says to put in a 25:1 gas oil mixture.
jordan /
OP
thanx
