Re: garelli super sport timing
Joe Woods /
The divots are in the correct general area to be timing marks..
Try this.. it's a trailerpark method of ignition setting that will get you in the ballpark.
Get a piece of cigarette paper and slide it between the points' contacts. Slowly rotate the flywheel while tugging on the paper. As soon as the points open the paper is released and that's where spark happens.
This should happen near where the divot marks and engine block mark are in alignment. If so, you're close.
As far as the timing light, my guess is it's not hooked up correctly or you dont have enought battery voltage to make it bright enough to see.
Whenever i've done it, the light is obviously on (but dim) all the way around 360 degrees.
  garelli super sport timingTopic by: Justin Elliott Justin Elliott 03/20/05 03:22AM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/20/05 03:49AM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/20/05 04:04AM
  Re: garelli super sport timingRe: Don Ohio Don Ohio 03/20/05 10:23PM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 06:53AM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/21/05 08:28AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 09:16AM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/21/05 09:34AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 09:52AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 10:34AM
  Re: garelli super sport timingRe: Tony Daniel Tony Daniel 03/21/05 10:39AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 10:46AM
  Re: garelli super sport timingRe: Tony Daniel Tony Daniel 03/21/05 10:51AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 02:26PM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/21/05 11:59AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/21/05 05:25PM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/21/05 11:57PM
  Re: garelli super sport timingRe: Tony Daniel Tony Daniel 03/22/05 08:42AM
  Re: garelli super sport timingRe: Justin Elliott Justin Elliott 03/23/05 02:41AM
  Re: garelli super sport timingRe: Joe Woods Joe Woods 03/23/05 03:41AM
