Leaking Carb
Hayden Stevens /
I have a 1978 Motobecane Moby....the carb leaks bad.....I know if I had a feul petock that worked, it would fix my problem..but I don't right now......the gas seems to be leaking out of the air intake
Is there a common problem with these?
Re: Leaking Carb
very common.. usually caused by a dirty carburetor. Chances are the float needle is not shutting off fuel flow into the float bowl.
Fuel eventually overflows and exits the carb at one point or another. In the meantime the bike's power suffers since a steady, regulated fuel level in the float bowl is required for best performance.
the fix is not related to a leaking petcock.
Re: Leaking Carb
yep
Re: Leaking Carb
Hayden Stevens /
I have 2 or 3 floats I could use, some have more needle or the pointed end and some have more needle on the flat end....which is better?...also the pointed end goes up right? maybe I put it in wrong, I can't remember
Re: Leaking Carb
John Joedicke /
Needle is facing up on those carbs
Re: Leaking Carb
There are a couple motobecane manuals HERE break>
"THIS":http://www.mopedriders.org/article_view.php?faq=2&fldAuto=18 one has exploded views and stuff about the carb and about servicing the bikes in general.
Re: Leaking Carb
Joe,
I enjoy reading your posts, you are very helpful on many subjects. I'm glad you hang out here.
gj
Re: Leaking Carb
well, thanks gjimmy .. same back at ya. You got a superior sense of humor which i envy a little bit..
