Targa LX a35 not sparking but horn works
I just re put together my targa lx i had blown the flywheel so i converted it to a point ignition with a coil, it sparked great, and it ran,the other day though it quit on me and now i cant get it to spark, but the horn works? Anyone know what it could be?
Re: Targa LX a35 not sparking but horn works
Don Pflueger /
check the tail light bulbs and go thru your wire job thoroughly. the horn is on a separate circuit from the ignition.
Gotta watch those Tomos tailights for sure.
John Getsch /
Why the tail light?
Don Pflueger /
its a safety feature to let you know that you have no rear lights and that is supposed to prevent you from getting hit from behind by a car. no light= no start= no riding.
I put the blue wire onto the frame, on my Tomos. Can't find 6 volt 10W bulbs anywhere.
John Getsch /
so your saying if the brake light isn't hooked up right it won't run?
Don Pflueger /
thats right. unless you have rewired it it wont.
John Getsch /
does it matter if the wires are hooked up to the light switch wear the handle breaks are. or just that the bulb is in and working.
Don Pflueger /
the bulb must be in and working
It's as simple as pancakes.
um no, my starts and runs just fine with or without the tail light/brake light and the wiring is original i hate messing with wiring
John Getsch /
I tested another coil so i dont' think its the coil, but how would i tell if it could be the condensor, or would that do it, i havn't checked the bulb yet, but i will.
Don Pflueger /
the only easy way to test a condensor is to remove it. and then use an ohm meter. place one meter lead on the condensors body and the other lead on the connector where the wires hook up. wait a few seconds, then reverse the meters leads. as you touch the leads to the condensor, watch the meter for deflection. a bad condensor will show very little or no deflection.
but first, make sure your points are clean and gapped to .014"-.016".
