carb issues, any ideas
Kevin Persinger /
so, my pugeot apparently has a leaky carb, but i have checked it several times, replaced it once, and have recently cleaned it. it doesn't leak when in use, as far as i know, but when ever it is moved it sometimes leaks for a while and then stops. i don't think it's the float, but i guess anyting is possible. any other ideas on how i can fix this???
side note...
i did take off the air filter, because it was broken, but i have a cover to prevent most crud from getting in. is it possible that not having it may be part of the problem. please help... any info would be greatly appereciated.
